Brief Description: Finished Countersinking & Deburring Side Panels
I finished up deburring and countersinking the F11 parts tonight. I countersunk the side panel structure where the spar carry-thru area attaches. The Zee Tunnel parts are all dimpled and will now fit when I reassemble everything.
I will now need to clean up all the parts, prime everything that will get installed soon and prep the inside of the side panels for paint. I wanted to wait unitl later on to paint the the panels, but figured it will be difficult to get a good coat of paint on every surface once installed. I'll just have to do touch up when I get the aircraft complete, because I'm sure things will get scratched on the inside throughout the rest of the build.
You can see in the pictures that I had to thread my countersinking bit directly into the angle drill. I could not access the holes in the few side panel angle well with my countersinking cage.
