Brief Description: Continued RH Side Panel Buildup
Continued with the construction order of plans sheet F12. Fitted and drilled the upper and lower motor mounts and the side panel cutout doubler. For future builders, make sure you include a .032" thick shim between the upper surface of the upper motor mount and the bottom face of the upper longeron. You can see this shim in the first pic. This space is where the glarshield will fit on a later assembly.
I also began placing and fitting the six gusset plates that will attach the various angle components.
