I installed the upper longeron bolts through the sidewall skins. It was a tight fit getting the nuts on inside the cross tie box. I put washers on the nut side of the bolt because there would have been excessive threads showing. The plans did not call for this, but it's a better install now.
I also starting working on, making, and gathering parts for plans sheet F15 - FWD Side Walls.
