Brief Description: Fitted and Drilled #2 & 3 Formers and Updrilled Tu
Today was fairly productive. I took care when fitting the #2 & 3 formers. It is easy to get gaps between the former flange and the turtle deck skin. I had to do some trimming on the #3 formers to get a good fit to the spline and fuselage verticals. There are several areas on the formers that will need to be tweaked when I pull them out for deburring.
Once I finished the fitting the formers I updrilled all the fastener holes for the turtle deck assembly. Now it's time to clean up, remove the parts and debur the gazillion holes!
