Brief Description: Finished Fitting & Pilot Drilling Aft Fuselage
Everything is fitted and pilot drilled on the aft fuselage as of tonight! Finshed drilliing the aft shear web, lower aft attach angle for the tail wheel bracket, and aft internal web. I also fitted and drilled the cross tie box clips on the RH & LH sides. These clips attach to the aft side of the cross tie box and the RH & LH skin. The last thing I had to do was layout and drill the top side of each upper cross tie that attaches to the upper LH & RH longerons.
Aft Fuselage Components All Fitted & Pilot Drilled
