Brief Description: Minor Finish Work On Stabilators & Test Fitting
After finishing up a few small items, I did a rough test fitting of the RH & LH Stabilators using the aft "Y" straps and the front attach angles. It looks like the bends I put in the hockey sticks are close enough that everything will mount together on the fuselage without much fuss. I also test fit the tail service bulletin doubler to get a better visual of the extra work associated with complying with it. You can see the extra strap/doubler in the aft view picture.
