Brief Description: Riveted LH Stabilator Structure & Drilled Top Skin
Over the weekend I was able to drill the LH stabilator structure and rivet it together. I also started skinning the structure. After getting a good fit, I piloted and updrilled the top skin and installed the 39 rivets through the top skin going into the fwd spar. Again, this is so I'll have access to the internal part of the sturcture to install the stab on the aft fuselage.
