Today I riveted the RT stab structure together and began fitting the skin. I was nervous that things wouldn't line up even though my measurments were correct. With just a little moving of the stab structure, everything lined up as closely as I can expect. I pilot drilled the upper skin and will finish drilling the lower hopefully tomorrow.
I had to spend considerable time studying the prints because there are several rivets that must be left out on the top and bottom aft areas of the stab until it is fitted on the fuselage.
