Brief Description: Fitted tail wheel and underside of fuselage.
We installed the tail wheel post and drilled and bolted it in place. Also we installed the belly skin and drilled that out to size. There are a few more holes to drill at the forward end then we can disassemble and deburr. Also we mounted the vertical stab,drlled to size the mounting holes, and bolted it in place.
