The carry-through structure was re-riveted on the top, drilled out on the bottom and is ready for the next step. The fuselage access panel cover locations were marked out and the screw holes were 'centered' and are ready for the correct size hole to be drilled. We noted that the print did not delineate the correct screw size for the access panel covers, but #4 screws were included with the fuselage hardware kit.
