Brief Description: Moved pallet and continued on fuselage.
Well last night we had a real good work session. We brought the pallet of aluminum stock from the white hangar into the clubhouse. We then removed all pieces and wiped them with BO Shield to prevent corrosion. The protective paper (we found out) will hold moisture and cause corrosion. Afrter that we got busy on the fuselage. We broke off into small groups and made many parts plus drilling and deburring. A great amount of work was accomplished.
