Rans S-7S Courier
S7S
Wing RH
10-6-2009
05F-04
Leading Edge Skin Support Tubes
Cut raw stock tubing to fit between each rib.
Distance 3 3/4" from the aft edge of the leading edge wrap
Drilled through the gusset into each rib and rivited the gussets to the ribs.
Modified two end gussets.
Gusset
Support tube
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
