Rans S-7S Courier
Date:  8-30-2009
Number of Hours:  1.00
Manual Reference:  05C-01
Brief Description:  Aileron Bellcrank and Cable Installation
Bolted the Aileron Bellcrank assembly to the wing frame as per parts manual.
Installed the Aileron Cable and Aileron Link Cable to the Upper Arm Bell Crank as per parts manual
Checked entire asssembly for free movement and friction.
Routed cables through ribs and through the Cable Rub Block.
Cut anti-chafe to length and add to the top of the second diagonal to prevent the cables from rubbing on the frame tubing.
Aileron Bellcrank
Aileron Bellcrank
