Rans S-7S Courier
S7S
Wing LH
9-12-2009
05A-04
Wing Frame Assembly
Started with the Lefthand Wing
The building of the LH Wing is almost a copy of the righthand wing exept for the Pitottube and Static system installation.
All parts deburred before installation.
Installed the inner and outer compression tubes.
Installed the aileron cable rub block and the aileron retention plate.
Installed the compression tube doubler in the compression tube.
Installed the flap and bell crank compression tubes.
Installed the jury strut bracket.
Assembled the teleflex retainer and the cable guide to the flap compression tube.
Installed the door up catch socket.
Installed the drag braces.
Installed the bell crank braces to the u-bracket.
Installed the tip bow.
Installed the nutplate for the aileron hinge bracket.
LH Bell Crank Brace
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
