Rans S-7S Courier
S7S
Covering
12-17-2011
07F-01
Elevator
Attached Nut plates for control horns
Drilled second control horns
Cleaned entire frame with Acetone
Both sides of the elevators are covered with a seperate piece of fabric. Glued fabric all the way around the frame tubes. Let dry and final ironed the entire surface for tightening of the fabric.
RH Elevator
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
