Rans S-7S Courier
S7S
Covering
4-10-2011
07A-02
RH Wing Covering
Turned the wing, bottom side up. Marked the trim line along the fabric perimeter and cut the fabric to the final size.
Glued down the fabric around the leading edge, trailing edge, tip bow and the root rib.
The rest of the afternoon was used to iron out the wrinkles and puckers in the bond area.
RH Wing Top
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
