Rans S-7S Courier
S7S
05G-01
Pitot and Static System Installation
Temporarily installed the pitot tube through the predrilled hole in the left wing leading edge.
Routed the two plastic lines for pitot and static as per figure 05-26.
Attached the lines with small clamps to the forward rib stiffners flanges.
Secured the lines with plastic ties to the drag brace.
Installed two 90 degree union elbow fittings to the pitot tube side of the lines.
Removed the pitot tube for covering and painting.
Taped the line ends closed and marked the root ends with pitot and static for ease of identification.
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
