Rans S-7S Courier
S7S
05D-01
Fuel and Vent Line installation
Cleaned the vent lines in and outside before installation.
Installed the forward vent line. Used anti-chafe tape at the clamp positions.
Installed the aft vent line and connected the aft and forward vent line with the 90-degree fitting.
Located the gussets on the rib stiffners, drilled and rivited the gussets in place.
Installed the forward vent line inboard to the tee fitting on top of the tank.
Taped all tube openings closed for covering and painting.
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
