Rans S-7S Courier
S7S
05C-01
Aileron Cable Installation
Installed the Aileron Cable and Aileron Link Cable to the Upper Arm Bell Crank as per parts manual, included the two stainless steel bushings.
Installed cotter pins and tighten all connections.
Checked entire assembly for free movement and friction.
Routed cables through ribs and through the Cable Rub Block.
Cut white plastic anti-chafe to length and added to the top of second diagonal.
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
