Rans S-7S Courier
S7S
05C-01
Aileron Bellcrank Installation
Transfer drilled the compression tube and the compression tube doubler at the predrilled locations with a #11 drill, used the bearing mount blocks as a guide.
Bolted the entire assembly to the wing frame as per parts manual.
LH Aileron Bellcrank
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
