Rans S-7S Courier
S7S
02B-01
Elevator Control System
Installed the swivel joint.
The swivel joint will allow the push pull tube to remain straight, when the torque tube rotates with the control sticks for aileron deflection.
Installed the idler brackets at station 6.
Checked the elevator control system for clearance, friction, and play
Push-Pull Tube Linkage
Swivel Joint
Idler brackets at station 6
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
