Rans S-7S Courier
S7S
Final Control Stick Assembly and Installation
Installed the torque tube in to the fuselage. Attached the control sticks to the torque tube.
Installed the linkage between the eyebolts in the aft stick and the push-pull tube.
Lots of time was used to sand and adjust the Pillow Blocks to make sure the torque tube moves without excessive friction.
Checked the entire Control Stick Torque Tube assembly for free movement and proper installation of hard ware.
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
