After the gear is placed in to the sockets one has to make a alignment jig to set the axles straight.
With the gear legs properly set one has to mark the gear legs by use of the pre-drilled hole in the fuselage socket, the gear legs must then be removed and finish drilling from each side in a drill press.
The gear will be installed after covering of the fuselage.
