Rans S-7S Courier
S7S
Stabilizers,Ailerons and Flaps 1 coat of white Pol
Cleaned the entire paintbooth which was full of silver dust from spraying Poly-spray, lots of work :-(
Mixed the Poly-tone with reducer 65-75 4:1
Cleaned the entire surface with a rag and C-2210 paint cleaning solvent.
Sprayed one even coat of white Poly-tone to turn the dark silver Poly-spray white.
This old trick will give a better coverage and a much brighter yellow.
Aileron
Flap
Stabilizer
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
