Rans S-7S Courier
S7S
Bootcowl
Used 600 grit waterproof sandpaper to sand the bootcowl and cowlings.
Sprayed one layer of white epoxy-primer on to the cowlings.
Let this dry for a few days before sanding out the imperfections caused due to spraying, I had a few runs, took care of them with 400 grit sandpaper.
Spraying the final color will be the next thing to do.
Bootcowl
Epoxy-Primer
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
