Rans S-7S Courier
S7S
1 Coat Polybrush on RH Wing
Thinned the Polybrush 3:1
Cleaned the entire surface with C-2210 Paint Cleaning Solvent.
Gently wiped the surface with a tack cloth to pick up last minute dust.
Sprayed a medium coat of Polybrush on the bottom side of the RH Wing. After a few hours drying time sprayed a second coat.
This last coat must dry overnight before spraying the last coat, this allows the solvents in the sprayed coats time to evaporate.
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
