Rans S-7S Courier
S7S
07A-03
RH Wing Inspection Rings
Glued the strut plate exits, jury strut exits. Layed out and bonded the inspection ring, flap teleflex exit and the aileron push pull tube exit.
Glued on the two drain grommets. Cut out fabric patches and glued over the corresponding parts.
Cut to lenght and glued the 2" Tapes over the ribs.
Next job will be to apply the 2" Tapes over the top-ribs etc.
Now finished for the day.
Inspection rings
2" Tape
Sealed with Polybrush
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
