Rans S-7S Courier
S7S
07A-03
RH Wing Cover Straps
Applied the small double stick tape on top of the fabric centered along each rib and extending 1/4" past the first and last hole.
Cut lexan straps to lenght and glued on the cover strap centered on top of the rib holes.
Used a hot soldering iron and melted through the cover strap and the fabric into the rib hole.
Cut the melted build up on top of the lexan straps with a racer blade.
Inserted about 150 rivets on the top surface and riveted
Two way Tape
Riviting
Top side Finished
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
