ONEX #54 Web Site
Date:  1-12-2012
Number of Hours:  5.00
Manual Reference:  W04-01L
Brief Description:  Left aileron complete
Through drilled ribs using skin pilot holes. Through drilled hinge pilot holes into the skin. Clecoed all together and updrilled holes with 1/8" bit. Disassembled, deburred and reassembled. Weighted aileron to keep it flat and installed rivets. Torgue on the counterbalance bolts will wait until final assembly to the wing in case they need to be removed for some reason.
Both ailerons are complete except for a couple of rivets that are too close to adjacent structure to install without an offset wedge.
This completed sheet ONX-W04, Aileron Details and Assembly.
Total time for ailerons was 33 hours.
Next I'll start on the outboard wings.
Left aileron done
Left aileron done
