Today I began work on the foreward deck. The various angle pieces needed wre cut, formed and drilled as required. The forward ribs, angle and subpanel parts were clecoed and clampd in place and match drilled. I have a panel on order so will need to wait for that to complete. Also, I found that I misuses a piece of .063 sheet and reorder another piece from Vans. This is for a plate used in this area.
The Andair fuel valve was drilled and mounted to the fuel selector plate.
