Riveted the baggage area ribs to the forward bulkhead of the aft fuselage. Then deburred, dimpled and countersunk the rivet and attachment holes on the firewall. The firewall was mounted on the forward fusealge structure and clecoed and bolted in place. Bolts were torqued to spec and Loctite applied.
Skip joined me after lunch and we riveted the bottom skins to the center fuselage and aft fuselage together. We also riveted the bellcrank support and ADHRS brace to the aft bottom fuselage. Lastly we riveted the aft side skins to the bulkheads up to the main longeron.
