Cut and fitted U-channel to length to cover edge of top skin above panel. I still need to glue this.
Pushed plane outside. Turned on avionic to check radio, but got no reception. I tried connedting the radio to the ELT antenna and that worked, so I investigated this as an antenna wire problem. I found one of the end connectors suspect so have ordered replacements.
I applied Smooth Prime to the wheel pants, leg fairing and intersection fairings.
