I respliced the VPX to Skyview cable as it had some extra length I didn't like.
The center panel was removed and then the trim switch wires were stripped, pins crimped and connectors attached. Matching trim wires to the VPX were fitted with mating connectors.
The GPS wires from the Skyview were fitted with a connector.
All switch wires were fitted with crimped terminal ends and attached to their respective switch.
With this nearly all cabin wiring is complete so I straightened and wire-tied exerything to make it neat.
With this wiring complete I removed all of the Dynon components and also removed the VPX.
