Mounted the EFIS screen, COM and Intercom i the left panel and then mounted that to the fuselage.
Installed the Airspeed Indicator I received from Van's over the weekend. Installed fittings and cut tubing to length for installation.
Sorted through the many wires from the EMS module to sort out which ones went where, then marked them appropriately. There seem to be a lot of unused wires so I will plan to remove these once I confirm they are not needed. The harness I built to handle a wide variety of engines and accessories so it is no surprise there are some extra wires in the package.
Installed fuse connectors in the wires going to the ammeter shunt, as was recommended.
Installed Skyview cables between the intercon, com radio, hub and EFIS.
