Brief Description: Gear dampeners, Flap hinge wires
The gear leg dampeners were cut to length and attached using Gorilla Tape. I had to cut them a little shorter than planned since my hinges are further from the edge than spec'ed but hopefully they will do the job.
Cut center 3 eyelets from the flap hinges ( one on wing, 2 on flap) to proved easier way to insert flap hinge pins. Pins were then cut to length and bent so they can be safety wired.
