Today I laid out my simulated panel using cardboard cut-outs for instruments and installed it in the fuselage. After sitting in the pilots seat I like the layout butr will continue to consider it before I make the cuts in the panel.
Wiring work continued. the last two wiring harnesses were laid in and the pitch autopilot wires also run. Then I worked on straightening and bundling all the wires to make the runs as neat as possible.
