Bills RV-7 Build Site
RV-7
Electric cable, sniffle valve
Another day where I had a hard time getting traction, but I did get a few things checked off the list, so to speak,
The electric cable running from the master relay through the firewall and to the Vertical Power VP-X was fabricated and installed.
The Alternate Air control cable was cut to length and installed to the cockpit and through the firewall.
The cabin floor was given a good vacuum and wipe down. Hopefully I am through drilling through the firewall.
The cover below the heater outlet was notched for the throttle cable.
The "sniffle" valve was installed on the induction sump and the drain tubing cut to length, formed and installed.
Electric cable
Cover notched for throttle cable
Sniffle valve and tubing
RV-7 Home
2070
184
954
Landing gear
Service Bulletins
Tanks
352
