Bills RV-7 Build Site
RV-7
Fitting empennage
Remade elevator stop and drilled it to the VS rear spar.
Trues VS to perpindicular to HS, then drilled rear spar to end bulkhead and tailwheel mount.
Set proper height and angle for front of VS and clamped and then drilled the front spar to the attach plate.
Completed elevator pushrod tubes by riveting end pieces to tubes and inserting end fittings and set to proper length.
Installed elevators and attached read pushrod to elevator horns and bellcrank.
Attached rudder and checked for proper movement.
Finishing Kit was delivered and I moved it into position in the hangar. Unpack and inventory will wait.
Elevator stop bolted to VS spar
VS front spar drilled to attach plate
Finishing kit arrives!!!!
RV-7 Home
2070
184
954
Landing gear
Service Bulletins
Tanks
352
