Brief Description: Skins, side plate, deck, gusset, more
Today I worked on riveting the right side. The side skin below the cockpit area and below the tail were riveted to the main longerons. The canopy deck was riveted to the main longeron. The firewall gussett was drilled to the longeron, removed, all parts deburred and then riveted in place. This completes page 8-10 of the manual, which has taken quite a while!
The shoulder harness brackets were drilled to the main longerons, deburred and then put away.
The angle was riveted to the vertical bellcrank support and then the support was clecoed in place and riveted to the bulkhead.
