A few more preparations for riveting of the side skins and forward bottom skin, which is planned for next week.
I marked rivet lengths on the skins using a sharpie. There are many different lengths that will be used in the next riveting session and having this marked on the skins will expedite the process.
There were a few rivets that I could use the squeezer on so I set those.
I opened the crotch strap kit and reivewed the instructions. Glad I noticed that because I will need to install these as soon as the fuselage is turned upright.
I also constructed stands for the fuselage when it is turned right side up. These will be pretty low to the ground but hopefully will put the fusealge at a comfortable height to work on. If it is too low I can always block it up some.
