Brief Description: Complete prep, begin reassembly
Began by marking layout for mounting holes on ARHRS tray. Drilled holes, deburred, dimpled and riveted platenuts to mounting holes. Clecoed ADHRS tray and brace to aft fuselage. Riveted forward flange of brace to bulkhead.
I dimpled the rear bulkhead on the center fuselage, whcih I rememberd in the middle of the night.
In spite of the windy day I was able to prime the main longerons. Once that was done I began reassembly of the fuselage. The longerons were inserted into the aft fuselage and clecoed in place. With the help of our fuel truck guy we lifted the center fuselage section into place on the longerons and nested it to the aft fuselage. The center fuselage bottom skin was clecoed to the aft fuselage bottom skin. The F-623 corner ribs were clecoed in place and then riveted as appropriate.
I also began clecoing the forward fuselage structure back in place.
