Today I continued work on the bottom skins of the right wing. I elisted the help of the fuel guys to assist in moving the left wing from the table back to the cradle and moving the right wing from the cradle onto the table. I continued riveting the inboard sklin, completing all rivets except some that can be maore easily accessed through the access holes when the wing is back in the cradle. Then I moved on to the outboard skin, and nearly completed it. One more session should finish the bottom skins. Today I drove a lot of rivets and getting the bucking bar on the inside requires getting your arm into so very tight spots. Both forearms have lots of red marks and a few cuts from all this.
