Brief Description: Assemble elevators to vertical stabilizer
Finally got back to some unfinished business on the empennage. Used fluch pull rivets to complete elevator skin attach to rear spar. After 2 trips to the hardware store I got the correct size wrench and tightened the jamnuts on the elevator hinge bearing rods and then applied Loctite. Assembeld the elevators to the vertical stabilizer using the specified bolts, washer and locknuts. Tightened appropriately and applied Loctite. Elevatoprs move freely with no binding, so it was time to put it back into its storage cradle.
