Brief Description: Drill right leading edge and tank
Match drilled all rivet holes in the right leading edge and right tank. Match drilled the tank skin to the joint plate. Countersunk tank to baffle rivet holes using countersink cage. Fabricated tank attach angle from angle stock using band saw for rough shape, file to final shape and grinder to finish edges. Drilled rivet holes in attach angle. I was really pleased with the way this one turned out.
