Brief Description: Rivet HS skins to rear spar and ribs
Riveted left and right HS skins to the rear spar and the inboard and outboard ribs. Used the pneumatic squeezer, which makes quick work of these long rows of rivets. It is nice to know you always have a perfect shop head on the rivet using the pneumatic squeezer once you get it set up properly. I left the outside plastic (the blue stuff) on to protect the aluminum skin from scratches, but will remove it before putting the assembly in the storage stand.
