Brief Description: Working on the Seat Brace, cold day.
A little machine work on some angles, they are to reconnect the brace to the structure I sawed it off from. In the end, it is stronger than when I cut it apart, and will be very easy to take it out or put it back in. I actually made two sets, in case I decide to make another 12, or screw up the first set.
