Brief Description: More Odds and Ends - and WINGS!
Got a lot done today, temperature was backed down a bit from a bunch of hot days, did not get hot until 3 in the afternoon! Changed out the main fuel pump to one that takes less amps and does not heat the fuel so much, and of course due to fittings, everything changed and took a lot of effort to make it all fit together again. I did get all the seat belts bolted on to the frame, and am trying to button up some of the interior now. I put some spray foam on the grooves of the baggage bulkhead so as to not get exhaust fumes and smells thru those openings. Just forgot to take photos of those projects for the log, maybe I will add them tomorrow.
