Don Schwanke's Air Force One
Date: 2-24-2016
Number of Hours: 0.00
Brief Description: Wings Nearing Completion
Back to work, trying frantically to finish the wings and get them back to the hangar before Mike leaves me stranded with them here at the house. Besides, Geneda wants her parking place back (and I would like to have my Mercedes inside as well) Had to engineer some things since the wing tanks were not an option when building the wings. Finally realized that the web between two lightening holes needed to be removed, reinforcements added, and allowances made for the wing to be moved out a bit to flip the quick connects apart. Got that all done, and finalized the wing wiring as well, these plugs in image three connect with similar plug on the fuselage. This is an upgrade from the original which was a very poor system. Only had eight wires in the plug, I used them all, so I cannot add more electircal junk to the left wing! Next up is making quick disconnects for the pitot and AOA lines, showing in the upper edge of photo 3. Brain has turned to mush, will do that in the morning.
