Getting the temp sensors for oil and coolant threw me for a loop. I could not explain the wide space between the two identical temp sensors. After some study, I found I had not changed the oil temp sensor in sensor setup from its old Rotax sensor. With that fixed, they both read the same, 76 which is where we have our thermostat in the house set at, so must be pretty darned accurate!
