It is often the simple things that cause more work and expense. When wiring my dual fuel pumps, I needed 15 amp breakers. Simple enough, I probably just took the cheapest ones. Problem is, now when I turn on the master, one or the other fuel pumps will run churning fuel in a viscious circle. Not a problem when the plane is finished, but while still having a lot of electrical system work to complete, that just don't cut it. So now I just had to change breakers to ones that you can pull the stem and turn off if you want. Just cost $43 and some work to do that job over and have new breakers. Some concentrated thought process while building a plane, often saves time and money.
